11 Seconds In 1/4
Old 12-23-2007, 01:39 AM
SILVERSLEEPER's Avatar
11 Seconds In 1/4
All of you guys that have done it, what is the cheapest way to do this in a 2wd 2005 ram. Nadp tranny is 4500 plus converter is another 800-1000 so were at about 5500. What else? I want to do this without nitrous, and single turbo. Keep in mind I'm 21 and my budget is pretty tight...SO please, you serious drag racers HELP ME OUT!
Old 12-23-2007, 01:46 AM
I already have a Banks intercooler/highram, intake, and 5" exhuast.
Old 12-23-2007, 04:12 AM
ramtd02's Avatar
you would need at least 100hp injectors, stage 3 cp3, silverbullet, smarty/dr.p predator stack, or PPE/dr.p stack. Then you would need some dyno tuning, and that would get you into the general range needed for a high 11 second run.
So I would say your lookin at $11,000 plus labour....this includes the purchase of the tranny.
Old 12-23-2007, 05:24 AM
morkable's Avatar
Seeing as your truck is a 2 wd, you will have some traction issues,,, you will need to look at some slicks as well as some suspension work
Kevin
Old 12-23-2007, 06:17 AM
ramtd02's Avatar
ahhh yes i forgot.....you will either need too find a set of slicks in a 17" or convert the rear brakes to a second gen design too fit a set of 16" rims......also you will need a set of caltracs, and probably need too remove a couple of leafs too get the rear suspension flex that you will need.
Old 12-23-2007, 10:36 AM
omaharam's Avatar
Now that's funny right there. I don't care who you are. That's funny right there.
Old 12-23-2007, 10:41 AM
DPS3's Avatar
Just run 2 leafs and a set of cal-tracs along with some slicks from M&H. They make some for 17"wheels anywhere from 28.5 to 30" tall. With that setup you shouldnt really have any problems hooking up on the track.
Old 12-23-2007, 12:27 PM
bighornram's Avatar
21 on a tight budget with an 11 second 2wd Cummins. Good luck.
Old 12-23-2007, 12:57 PM
trefling's Avatar
At 21 your better off focusing on some other things rather than spending your way to 11's. BTW, in my opinion to do it right you'll need roughtly 12-15 grand to do it right
Old 12-23-2007, 01:16 PM
haloman's Avatar
Near impossible unless you win the lottery with your budget
Old 12-23-2007, 01:44 PM
Erik@LCD's Avatar
You need about 800HP. So HUGE fuel/turbo setup, good trans,etc. Trying to get there without N20 is going to be pretty close to impossible on a significant budget, let alone a "budget" budget..
Old 12-23-2007, 02:13 PM
DTR 1st Sergeant
soulezoo's Avatar
I've spent over $10k (tranny/twins/smarty/odds&ends) just to get to 13's! The first few seconds shaved are the easy part-- getting lower is the hard part. The amount of $$$ spent per tenth of second shaved goes up very fast once you get to the 14's.
Old 12-23-2007, 03:15 PM
omaharam's Avatar
I agree it's not really feasible on a budget, but you guys do need to remember that he's got a 2wd regular cab. It will take a lot less for him than for most of us. If mine was a 2wd reg cab I would think low 12s would be no problem.
Old 12-23-2007, 04:15 PM
DTR 1st Sergeant
soulezoo's Avatar
Well, yeah, there is a big weight difference and mechanical resistance difference too. However, boosted 4wd launch in the 1.65-1.8 60ft range makes up for an awful lot of weight evil!! It also makes for some broken shafts too...
Old 12-23-2007, 05:09 PM
madhat's monkey boy...
matego's Avatar
I think with the right rear suspension set-up a 1.65-1.8 60ft. is in no way out of the question. Big ol' slicks do wonders for that. I know I would get off the whole "nitrous is cheating" kick and go that route. You would have a LOT more money to put where it is needed. I have never seen a real 800hp fuel only truck except for the tractor pulls and it looks like it would be a nightmare to drive on the streets.
I guess we all have to learn on our own sometimes. I remember my 74 Nova with 350, 12-1 comp, huge roller cam, tunnel ram intake etc. that looked real cool but was horrible to drive around.
Quick Reply: 11 Seconds In 1/4
