11/32 drill bit for 1/8" tap?
Can I use an 11/32 bit to drill for an 1/8" npt tap? Says on the tap use q drill bit, but will an 11/32 size bit work?
Drill chart
IIRC, I used a 5/16" bit for my 1/8 NPT tap. If were to use a 1/4" NPT tap, it would a 7/16" drill bit.
I used a 21/64" bit. Worked fine and was available everywhere I looked. Luckily I had one and after sharpening it had no problems. I think it's more important to drill a very straight hole. A bit that's 1/64" + or - probably has less effect on the tapping process than a hogged out hole or one that's improperly cut.
Aloha
Aloha
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
finndogg54
09-17-2007 11:12 AM
Dodgezilla
08-22-2004 06:12 AM
