1 Year old F1 Helix2 Cam report/Valve lash check
Today I got off my lazy butt and decided to change the oil (has 6 hooks on it and about 1000 miles).
I also thought it would be a great idea to run the valves and see what needed what as far as lash adjustment went.
Here is what I found:
Every intake and exhaust valve was only loose by .000" to 001". Basically no or a negligible amount of wear to report and with human error when setting lash the cam might not have worn at all.
The cam has about 15 +/- hooks to the sled on it so far.
I can say this really makes me happy to report this cam is holding up great as far as what the valve lash is telling me.
Oh yeah, I went ahead and changed the oil and filter while I was at it. I Installed the typical Fleetguard unit and a mix of 8 quarts of Valvoline 20w50 and 4 quarts Valvoline 15w40.
I used the ratio to make sure I got the benefits of the diesel additive package in the 15w40 but also have the added benefit of a heavier weight oil now.
I'm going with a Helix 2 whenever I can steal it away from Brandon (Joefarmer)...he won't give it to me after I traded him some parts for it
Chris
I would love to have one too. I could save the $ to buy it, my deal is intallin it. That looks like a major pita.
CQ, you have come this far, may as well go all out now.
DTR Advertiser
The cam should take you and a helper about 7-8hrs the first time you do it. We can do them in about 5hrs now. Nothing real hard but there is a lot to disassemble/assemble. Tim
Chris
When I did my install I had to cut the top of the front fender support (it keeps the fenders together). The problem is removing the cam with the gear on it. So you take the bolts out of the fender support, slide it over a bit to center the slot around the cam, and cut the top out of it. It is hollow and slotted (kind of looks like a giant version of unistrut except boxed). I welded the piece I cut back in but now I wish I would have welded tabs on it and bolted it back in because I'm going to do it again.
REDNECK-WELDING
04-04-2008 06:06 PM
moparman13045
02-27-2008 11:28 AM
82NDSNPR
09-18-2007 08:17 PM
RyeThomas
12-19-2006 05:10 PM
