1 Inch Lift???
1 Inch Lift???
I just finished the superlift kit on my 07 and the front easily sits a inch lower than the rear does anyone know of a inch to inch and a half spacer for the front anywhere i really dont want to go two because it will be too much any help would be apperciated
I have the opposite problem, installed 2" leveling kit, and now the front sits a tiny bit higher than the rear. I tow and haul alot, so I guess my rear springs have settled.
Superlift makes a 3/4" steel spacer that goes in the bottom coil bucket on the front axle. It must be welded in place. Part#4520. They are made for
2nd Generation trucks, but should fit 3rd generation trucks. If you can measure spring diameters or give Superlift a call.
I believe Don Thuren is working on some fine tuning spacers. You may want to give him a call. Good luck!
hwebb
03-01-2010 12:42 PM
KKoteles
30
04-16-2008 11:07 PM
KKoteles
06-19-2007 06:06 PM
