'07 Dually lift question.....
I am giving serious consideration to installing a Rize lift on my dually. Several other lift kits specifically state that the rear lift (blocks) do not work on a dually application. I am awaiting a response from Top Gun for the Rize lift.
What is the difference between the rear spring arrangement on a 2500 or 3500 SRW vs. a 3500 DRW and why wouldn't blocks work on the DRW. I suppose I could have custom springs made, but that would add significantly more cost to an already expensive kit.
Thanks
Thanks
Hello The blocks will work in the lift kit The only thing you will have to do is get custom u bolts. The axle in the daully is a 1 1/2 ton and requiers bigger u bolts. That is the only thing that you should have to do to make the kit work. If i were you i would look in to a custom set of springs. The big thing that i fear is kicking the block. Good luck.
Bobcat698
09-12-2006 08:36 AM
CTD NUT
09-12-2005 04:40 PM
RobG
09-05-2003 09:13 AM
patriot pearl blue
12-09-2002 08:53 AM
