07 Differences From 06
I'm a newbie with 07 Mega Cab, having trouble finding intake, everything lists thru 05 or 06, Even called AFE and they didn't know a difference but told me to err on the side of caution and not order the intake for the 06 yet. Whats up, anyone know ???
pretty much all 06 products will work with your 07. Everything I have installed was listed as 06 products.
The only thing I had a problem with were my nerf bars. The 07 cab has a mounting bracket on the passenger side the 06 doesn't.
N-Fab has fixed that problem with their bars but, keep it in mind if you happen to purchase some from somewhere else.
sensor on air box
What about the sensor on top of the air box? Is it the MAF or Intake temp sensor? Also to all the aftermarket intakes come with the place to connect it up to.?
Don't know about all but, I do know the AFE and S&B CAI's do have the hole to mount the mass air sensor. Even if one you find doesn't...it's just a matter of drilling a hole, getting some double sided foam tape and you're good to go.
j28s
02-14-2003 04:14 PM
joel
11-11-2002 09:14 PM
