'06 warranty (with mods)
Newbie here. Will any of the following mods void the '06 warranty?
1. 2 micron supplemental fuel filter mounted between stock FF canister and the CP3.
2. External fuel pump (system) using walbro pump.
3. Dynatrac front manual hub conversion.
Thanks in advance.
Thanks in advance.
- 2 micron filter not unless the restriction causes fuel supply issues.
- external fuel pump can void if it is outside of DC specs for the fuel system. This includes pressure and volume.
- front hub conversion will void the warrenty for the front axle. As you have now modified it outside of OEM specs.
LFD2037
06-08-2008 01:36 PM
gandalf1g
11-26-2007 02:31 PM
trik396
05-30-2007 04:42 PM
