06 MegaCab with 3 axles
#92
It really does pretty well in snow and ice. It's a little wild when that big rear end starts sliding sideways but rarely do you have to kick it into 4 wheel to get you through. There is a bit of tire scrub when you make turns but not as much as you might think. The tires on the front rear axle tend to wear just a bit faster than the rear but only slightly. The ride is very smooth but as long as it is it's much like driving a straight truck or a short bus. You don't get any up close spaces in a parking lot.
#93
I noticed for suspension you said it has the BDS long arm lift kit. I wounder, How does the leaf springs in the back work? It doesn't look like there is enough room between the axles to simply get two sets of springs , even if the 2 center perches shared a mounting point on the frame.
#94
#97
I know USA 6x6 made one of the vehicles but I am not certain which one. I'm not familiar enough with the show. I got to sit in it down at their shop. It was in there because the front axle was breaking in to. I believe the thing weighed about 16k. Hindsight being what it is, they should have used a heavier platform to handle the weight. I don't think the original design allowed for that much weight. It was pretty cool to sit in.
#98
with all the armor and hydraulics that thing had I'm not surprised it was that heavy, if I remember correctly they had an issue with one of the rear axles too. The first TIV was built on an older F350 frame with a 7.3 powerstroke for power
#100
I've seen cab and chassis rigs with an added tag axle, mostly hot shot trucks pulling a flat bed trailer. Even saw one with a sleeper with a tag axle. Looked like a mini 18-wheeler. I had thought about doing my dually this way (Quad Cab with 8 ft. bed) but didn't think a conversion to a live tandem axle could be done easily. I know it would help handle the load of my Fiver better. That will be one awesome rig. The tire store will love you.
09-22-2019 07:27 PM
95black2615
12-22-2007 10:54 PM
bigbrowndog
09-02-2007 08:16 PM
SkyHarborCowboy
15
09-09-2005 11:50 PM
