06 knock! PLEASE HELP WITH ?
Can I borrow a trailer loaded down I put some Power Service Diesel Kleen in my tank today when I filled her up! You have heard my truck what do you think it is or is it normal.
It sounds like my dads 04 when you are stock but it has a lot more rattle when on smarty#9 but that is expected. I think you should are fine, if youre extra worried check your oil and smell it for diesel smell and if the level gets higher then you have a bad injector but if not then dont worry.
It doesnt idle rough or white smoke it just has a knock or a ticking sound. Ive taken to two dealers now to try to get to the bottom of it and they say its carbon build up on the injectors. They said a injection cleaning will help but it is $100 didnt know if I should get that or not or would I juse me giveing them my money cause its not covered under the warn.
That is correct! I don't have that injector tick/knock that these 3rd gens seem to have. Increased mileage and the truck idles smoother. I've noticed when I don't run the 2-stroke (when I add Stanadyne) the injector tick/knock surfaces.
Are oil supplier has an 06 and he's taken it it many of times for the tick/knock, I told him about the 2-stroke and pretty much eliminated it after 1 tank.
I add 1 quart every fill-up. Every 4-5 tank fulls I run Stanadyne through it just to clean any sort of carbon build up that may have occurred. I'm using the Walmart TCW-3 2-stroke. A gallon is about $8 bucks.
I would recommend Howe's additive. It seems uys around here have had issues with it, rough idle, white smoke.
I did run some cleaner through mine and guess what, KNOCK KNOCK now. After reading many posts here, I was wondering if there is value to running a lubricater instead of a cleaner, or possibly vise/versa? Maybe the aftermarket setup of a particular truck would deem which one is neccassary(if at all)? Just a random thought.
HappyGA
15
10-16-2006 08:21 AM
Hoss
30
10-03-2006 02:57 PM
