05 cr injectors
Old 12-13-2008, 02:39 PM
nwflyoda's Avatar
05 cr injectors
since my issue w/ the injector in my truck, i've been looking at aftermarket ones in case this happens again (i am still trying to get my money back). i would only be looking at the 50-75hp range. the truck is used primarily as my tow rig and also a DD. although i do play w/ it on occasion. which ones would you guys recommend?
Old 12-13-2008, 03:01 PM
megacabdad's Avatar
Check these one's out...
http://www.f1diesel.com/injectorsecho.html
Then there are...
http://www.dynomitediesel.com/prod_display.php
Old 12-15-2008, 07:14 AM
nwflyoda's Avatar
anyone know anything about the ATS injectors?
Old 12-15-2008, 09:28 AM
04DEEZELRAM's Avatar
I would use F1 or DDP injectors before i would run atsones.. hey man where you at suncoast dyno day in feb?? do you know if there having it again?
Old 12-15-2008, 04:03 PM
nwflyoda's Avatar
is there something wrong w/ their injectors? yeah, i was there. they will be doing it again but it will be a little different i believe. i don't know the details yet though.
Old 12-20-2008, 01:08 PM
gus's 03's Avatar
only thing ive heard is its tough to know what your getting. some are honed, some are edm'd, aperently from a few diferent scources, and a few diferent quality standards.....
Old 12-20-2008, 07:19 PM
Nsomniac05's Avatar
I cant say for sure what DDP does to get the stage 2 90's but i know for sure they have between 90 and 100 hp added and also mpg gains of 2+-. and I havent had any trouble out of them what so ever. Definitely worth 600 bones.
Old 12-21-2008, 02:18 PM
nwflyoda's Avatar
where did you get them for that price? if you can pm and let me know.
Old 12-22-2008, 12:00 AM
Nsomniac05's Avatar
i got them a year ago on tvdiesel.com they were about 1000 then i got a $400 core refund when i sent them my injectors and they ok'd them. i just checked and they advertise for 800 but they are actually 1200 and when you send them the removal tool and your injector tips back, if they pass inspection, you get 400 credited back to you.
Old 12-22-2008, 09:30 AM
nwflyoda's Avatar
are they just tips or complete injectors? i've been told to stay away from just tips.
Old 12-24-2008, 12:48 PM
Nsomniac05's Avatar
tips, needles, springs, and the tool to remove them. theres nothing wrong with tips. thats all youll get anywhere except for Formula1. and that is top of the line stuff and is priced accordingly. if you dont have bad injectors, i dont see why you need a full rebuild, unless like i said your willing to pay for top of the line stuff from F1.
Old 12-24-2008, 02:12 PM
nwflyoda's Avatar
seeing how i've already had 1 injectors short out on me, i would be going w/ a complete setup.
Old 12-24-2008, 02:21 PM
silverrhino's Avatar
Send them to Don at F1. He can test the bodies and rebuild them if needed. and make the injectors to whatever hp requirement. Probably the best bet since you are having problems with them.
Old 12-24-2008, 04:47 PM
nwflyoda's Avatar
thanks, i'll probably go that route later. how long does it take to have them gone through and built?
Old 12-24-2008, 09:28 PM
DTR Advertiser
Timinva's Avatar
Don can normally go through them in 2-3 days from the time he receives them. Lately Don has been doing them within 1-2 days after I let him know they are coming. Tim
Quick Reply: 05 cr injectors
