04.5 turbo - same as 03 ?
Going to upgrade to a bigger turbo in my 03 ho , When I upgrade to a 05 I want to be able to swap most performance mods over.
Otherwise I will have to change plans.
Also what turbo seems to work best with the 03,s at hopefully about 450 rear wheel hp +/-
Thanks.
Thanks.
Different turbo on the 04.5, it has an electronic wastegate controller.
Also a larger compressor wheel and compressor housing.
Sort of like a hybrid 40.
--Justin
--Justin
i believe there is also 2 other sensors in the compressor housing on the new 04.5 engines... a turbo speed sensor and a temp sensor...
here is a cut away pic of it
J Lent
60
11-03-2009 09:14 PM
jmccart
01-18-2007 03:26 PM
