04.5 speed limiter
04.5 speed limiter
Just wondering has anyone heard or know how to overide the speed limiter? I assume its different from the 03 model. But i guess that would effect the rev limiter also. Any thought?
Originally posted by rmb93243
I was told my 04 had a limiter on it, but I ran her out to 108 mph and about 3300 rpm, which is where it redlined and hit the rev limiter.
Me too. I run out of gear before power or electronics. Check out www.bd-power.com they have one that does the speed thing and also gets rid of the torque management system.
I talked to bd-power, and they do have them avalible. The cost is about 200 plus shipping. I asked what the rev limiter is in overdrive, and he said 3600. If so that should put it up to around 125 mark. They gave me a number for a local dealer here in tx, so if they have one in stock im going to order one today. If not im going to order one monday. Ill let you know how it works out.
2004.5 3500, swb, sw, 4x4, 48re, black, tst prmx, muff gone
There was a post a while back on this and alone it knocked like 2/10's off the guys 1/4 mile time but that was mainly due to the torque management system. truck was an 03 auto. I called BD and they said that the manuals are affected but not near as much due to not being able to make boost at idle. (ECM defuels when boost is sensed w/o seeing vehicle speed.) But I know my truck defuels when I launch because it takes off then falls flat on its face then comes back on. On the second gens the ECM would defuel with the blue chip boxes because it didnt fool the computer when it seen a rise of 800 rpm or greater it would defuel. I would think that the 3rd gens are the same???
What is this torque management system? This is the first I have heard of it. I thought the TST box and the EZ both have a built in boost fooler to prevent setting a overboost code. Is this not the same thing the BD box does?
Thats great news , Ill add the Eliminator to my list. With all the mods Im doing, to have it defuel at 2900 to 3100 is unacceptable. I see you have the TST, I wonder if the TST box will need to be reprogramed.to fuel to 3600 rpm. Before you try it maybe you should call Mark to find out. Please keep us posted. thanks
My bro just got a hemi 5.7L 1500, we did a side by side, my truck blew him away on the start, but after say 1/4 mil he flew past me, I still had it floored, I looked at my tach, and it almost looked like the rpms would'nt go into the red. Truck was still accelerating, but not quite as quickly as I had expected. Of course I don't want this to happen again. What can I do to not get my warrenty voided, but still blow him away?
Possible it is true. I know on my 04.5 i can turn it toward the off possision shut my radio and everything off but the truck stays running, i chalked it up to a faulty switch or something haha. Good thing i havent had it fixed yet, Might have to try that when i get the truck back
