04.5 power ratings
04.5 power ratings
is it the 04.5 ram that is rated for 325 or did the 04 rated for that also? i trying to find a 04.5 and up ram but cant remimber the differences between the 04 and 04.5. thanks for any help!
Also, the 03-04.5 engines run alot cooler and get much better fuel mileage. It does take more $$ to get the same power output of them compared to the 04.5+ engines... if that is your goal.
You'll notice alot of the new trucks are making good numbers without aftermarket injectors.
I'm lookin to trade in my 2 genetation for a new one, what year would be the best to buy. I don't care bout fuel milage or nuttin like that just power. and what combo would work best to get 550? I know twins would be the easiest
Im real close to that number with what I have, I should be there with the headwork and injectors that I plan this winter. And still excellent towing machine
Kevin
Kevin
The 600 series motor will reach 500+ a lot easier than than 305/555. As for rear wheel hp. Yes it probably is 270 on a 6 speed. But the auto robs about 80hp so the are about 245 rwhp
Stock with the 48re......mine dyno'd at 280 hp/528 tq.....Dynojet.
Stock with AFE stage 2 and Magnaflow it was 277hp/547 tq...same dynojet a year later.
Added Smarty on level 5 and it is now 397.5/ unk on tq number
Transmission is all stock....but hopefully for not to much longer.
mine dyno'd at 348 with a bullydog pp, 4" MBRP and K&N FIPK, and a really really weak tranny. It was so weak that the dyno operator had troubles getting a good number.
Kevin
Kevin
dodgecowboy04.5
77
02-14-2011 08:29 PM
dodgestang
06-25-2009 10:06 PM
cdhd2001
07-28-2007 08:29 PM
