03 Throttle Position Sensor extension harness
Does anyone know where I can get a short extension harness for the Throttle Position Sensor on my 03? Or at least know what type of connnectors they are and where I can get them to make my own? I have something that needs to tap into those wires and I would rather not cut the factory harness.
I am going to relocate my TPS to under my battery and so far I bought the connectors, but haven't had a chance to make the extension harness. When I get home from my roadtrip I can look at the receipt and PM you back with the part numbers and website from which I ordered the connectors.
They are 4-pin Deutsch connectors - at least on my early 03 6 speed truck - that you should be able to buy from any wiring house. Different year and/or transmission trucks have different types of connectors.
You can order them from this site:
http://terminalsupplyco.com/Default.aspx
These are the connectors "Deutsch DT 4 cavity socket and plugs" for the early 03 trucks with APPS on the intake:
http://terminalsupplyco.com/pdfviewe...nals&page=p057
These are the same style of connectors for your injector harness into the valve cover spacer. You would also need the pin and socket terminals.
I don't know what the later APPS connectors look like - I do know, however, they require more cavities.
tishmael
13
12-02-2002 12:39 PM
