03 high idle
03 high idle
I realize this subject has been beat to death but I am looking for fast idle on my 03 CTD HO, manufactured late 2002. BD Power used to have a kit but it does not appear to be available anymore. Is anyone running the Diesel Service Group fast idle kit? What do you think of it?
L8r,.......dogger
L8r,.......dogger
I asked about that kit awhile ago and no one every replied, so I guess no body has ever gotten one. Im seriously thinking about getting one after the holidays, I will let you know if I do.
The 03 trucks only idle up to 1000rpm when its cold, other then that cut a stick and prop it from the bottom of the dash to ur throttle if you would like high idle. Its what I do and works great.
The cheapest solution is to rig up a univeral choke cable (or a stick) to the throttle linkage.
At one time I found a site with a electronic throttle control module that ties into the APPS sensor. IIRC was around $400.
MikeyB
MikeyB
it may be diferent on the 03 but on my early 04 i cut the wire going to the t-stat and ran it thru a switch and when i flip the switch it breaks contact and triks the computer to thinking its cold and she idles rite up,then flick the swotch back and she idles down,it has to be the wire that has power to it,5 volts i think so test before u cut,mite work on urs and alot cheaper than 250 bucks,got a switch at wally world for 2 bucks haha
Location: Used to be missoula, montana: Now in Sonoma County California
03 trucks lack the programming. some guys have installed a replacment facotry computer and had the dealership program it. the newer computer and programing has the high idle and the fog/highbeam ability.
there was a thread on this last year where someone finally pinned down the dates ect
jmccart
06-12-2007 02:12 PM
dieselnewbie
01-18-2005 10:48 PM
