03 Edge EZ hp/torque settings
Just got my Edge EZ and it gives you 4 different power settings but the manual doesn't tell you what the hp/torque increase is for each setting. Anybody know?????
Re:03 Edge EZ hp/torque settings
Well, if setting 4 should give me the most power then I got a faulty box. I was VERY disappointed when I installed it (it took a whole 5 minutes). I decided to see what setting 4 felt like and I couldn't even tell a difference from stock. I changed it to setting 3 and now I can feel the power. I've e-mailed Rod at Wildcat Diesel to find out for sure what the settings are. My box may be faulty in setting 4. It feels great on setting 3 but the roads are all wet this morning so I really couldn't test it because the tires just keep breaking loose...
Guest
Posts: n/a
Now you have me wondering??
But, I was in error. I went back and looked at my notes when I talked to Edge.
1=30HP (not 15)
2=45HP (not 30)
3=60HP (default)
4=70HP
My truck is the SO and the EZ has made a big difference on the default setting. More power and efficiency.
Rod may be able to shed some light on the issue though.
Let me know what you find out.
1=30HP (not 15)
2=45HP (not 30)
3=60HP (default)
4=70HP
Dieselhead
06-05-2003 11:33 PM
