03 4" exhaust
03 4" exhaust
Looking for a suggestion. I have an 03 QC HO CTD long box and looking at one of two exhausts; either the MBRP or the Banks. I'm doing a turbo swap so I'm going to lose the BD Power turbo mount exhaust brake I presently have and replace it with a in-line remote. The Banks system has an in-line exhaust brake that will connect right up to their exhaust in an abbreviated version. The MBRP will require slight modification. I am looking for the exhaust to be close to quiet as stock and no dreaded drone when towing a large trailer. Like to hear your opinions so I do this only once. Thanks!!
L8r,...........dogger
dogger,
Most likely if you're doing a turbo swap none of the systems will bolt on at the turbo, especially the Banks brake set up, check this out first based on what turbo you plan to add. If that is true get the MBRP or the AFE as they are much more economical, especially if you plan to have to modify them etc. If you have questions just call us.
Mark @ DPPI
Mark @ DPPI
roughstock
11-02-2013 01:48 PM
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
Hemlockusa
01-28-2006 07:07 AM
