03-04 Predator/powerpuck stack??
anyone running this on there's?? i got the predator on now, and it does awsome on 160hp, and i can tell it can handle more, just wondered how the powerpuck did with it?
It is an awsome stack. As mork said i put down 503hp on the dyno saturday on the stock turbo. Got up to 1500 on the pyro when i backed off at 3200 rpm. A little hot on the dyno, but ok on the street.Had an ez-bully dog stack before and dynoed 374hp. Quite a difference.
What boost numbers are you seeing with the stack, downloader only, and puck only? How about rail pressure?
Mike
i have the stack on my truck but i don't have guages yet but i 'll turn everything on every now and then for short periods. too much for the stock clutch though. i will probably order quad commander next week then i can play a little harder. But for $380.00 can't beat it. will get too a hundred really quick though.
Guest
Posts: n/a
03rmk- what settings did you have your bully dog and EZ on when you dyno'd at 374rwhp? i've got my bdpp on extreme and the EZ on highest setting (80hp, i think) and it FEELS pretty **** strong...but if that's only 370-380ish hp, I can't wait to see what 500 feels like (bdpp and EZ are in the classifieds for cheap and the predator/puck stack should be on the way).
