Torx bit size front drive shaft
Does anybody know what size torx bit is needed for the front drive shaft. I need to remove it so I can find that dang grease hole.
Not sure of the size, but make sure you heat the bolt/flange area up enough to help the loctite let go. If you warm it up good, the bolts remove easily, if not, you are going to twist the sockets out of the bolt. I replaced mine with hex heads. Good luck.
morkable
ABDTR #5
16
12-22-2008 08:59 PM
04ctd
11-25-2006 07:30 PM
jeeptjstud
12-14-2005 05:15 PM
