temp fluctuation please help
my temp started fluctuating, loaded and unloaded, changed thermost, still doing same, changed temp sending unit, still same problem, fluctates like an oil pressre gauge from 187 to 210, im driving 70 mph temp is fluctuating between 200 to 210 and its 50 outside, any sugestions......?????
Is it possible the T stat is cycling like it is supposed to? Does the cycle time increase/decrease with load and outside temperature? Did you take the T stat out and test it with a kettle or pot of water on the stove to see if it is opening closing properly? Is the highly accurate dash guage good? Is the fan cycling under hot water conditions indicating water temp changes?
I have an Edge Insight on my truck and I will state that the temps will hit 200 to 212 during a regen towing. Then when its done, its back to 189 to 194, floating around somewhere in there. That being said, if its constantly floating that high, there is an issue with the thermostat. Did you get a genuine one from Cummins? Also, could your rad be partially blocked?
Well, I don't know that it's normal. If we remember, lots of us thought the fluctuation was normal on the second gens too until Cummins came out with a different thermostat to take care of the fluctuations. My question is, do we have anyone who can certify that the fluctuations are attributable to anything... i.e., when the engine goes to regen mode.
one thing frustrating is that the 6.7 is smaller coolant capacity than the 5.9. 6 quarts is a lot of difference. finger they did that to keep things hot for emissions garbage along with the innercooler on the 09-newer trucks.
wonder if finding a way to get another 6qts in our systems would help any. just a thought
5.9L Diesel Engine 28.22 qts.
6.7L Diesel Engine 22.6 qts.
here is a list of Chryslers possible causes for
TEMPERATURE GAUGE READING INCONSISTENT (ERRATIC, CYCLES OR FLUCTUATES)
NOTE: Information on dash cluster is displayed based on broadcast data from ECM. DTC will be set for engine sensor circuit wiring.
1. Heavy duty cooling system, extreme cold ambient (outside) temperature or heater blower motor in high position.
2. Temperature gauge or sensor defective.
3. Temporary heavy usage or load
4. Air trapped in cooling system.
5. Water pump.
6. Air leak on suction side of water pump.
5. Water pump.
coalburner400
04-11-2008 10:16 AM
1stdodge
07-04-2006 11:34 AM
