See Dealer Now Message
Old 07-21-2009 | 08:23 AM
J3Cub's Avatar
I am getting a message on the overhead “Service Required, See dealer Now”
Is there anyway to cut this off without going to the dealer?
I am running a Smarty, and no codes are showing up. I talked to the dealer, and he said this is just a message to get you to come into the dealer.
I do not want to take it in, as I will have to uninstall the Smarty, so they can hook up to it, and cut the message off, then I will have to reinstall the Smarty Program.
Surely there is some way to cut this message off!
Old 07-21-2009 | 08:33 AM
klx650a2's Avatar
So, it almost sounds like they are advertising now in these trucks. Maybe if you wait long enough, it might offer a coupon for 10% off?
Old 07-22-2009 | 07:23 PM
zfort001's Avatar
Set parking break, Turn key to run (do not start) press go pedal 3 times slowly within ten seconds turn key off. Turn key back to run and it should go away. Usually its a oil change warning if no codes. Worked for me when it came on and got the oil changed at dealer and they forgot to reset the warning.
JS/08Ram3500
08-22-2012 07:33 PM
jnall
08-29-2011 04:32 PM
Polaraco
06-01-2011 12:16 AM
robby t
05-28-2011 09:49 AM
robby t
05-09-2011 01:12 PM
Quick Reply: See Dealer Now Message
