Pre turbo EGT probe installation location on 6.7l CTD?
I read this same post for tips on drilling before i did mine.
I used a right angle drill, Small bit first for pilot hole did not go all the way through with the first bit. Second bit was a little larger to get more metal material out of the hole before I went through. 3rd bit was the right size for the tap, I did the with the engine running, exhaust brake on , tailpipe taped up half of it to build back pressure, grease on drill bit. WEAR SAFETY GLASSES!
Worked like a champ as the manifold metal is kinda soft.
Just go slow and it will work out. I know what you're feeling as I was a little aprehensive of doing it myself. Once it was done I did my buddies also!
i paid my dealer one hour labor to install the egt probe, any issues and they have to deal with it, $100 is not worth my time even if nothing goes wrong. as far as the egt's go mine runs around 820 down the highway @ around 65mph, when it goes into regen the temps get up to 1200 or so, if you idle alot during the day like i do then once in a while your nox regen will kick in, the egts will surge to 1340 on the highway for about 4 minutes and then return to normal. hope this helps
installed my westech gauge today boost/pyro. here is the location i picked for pyro and the boost reading. overall it went well just took a long time cause i was careful.
tried it out on the way home going up hill 6th gear not a real big hill it was running 900 to 1000. does that seem right.
eastmentCTD600
01-11-2009 12:11 PM
thxman
04-30-2007 12:19 AM
HorseHauler
15
03-31-2005 03:28 PM
