PCM to ECM issue
Old 07-05-2012 | 06:01 AM
hoosierdraft's Avatar
PCM to ECM issue
My 2007.5 with 108K mileage was rolling down the road 2 weeks ago at 45mph. Out of the blue the dashboard lights gave a Fourth of July look and the motor died. Coasted in to a parking lot. Restarting the motor was a no-go. Towed to my local Dodge dealer. Mechanic said the PCM/TCM was dead. Took them a while to locate a replacement.
After locating and having it shipped, mechanic installed the PCM. Is currently stalled in programming the PCM. He says that the Startech(?) unit is not able to get the part number from the ECM. Says diagnostics show the ECM functional but not able to communicate with the PCM and has been confirmed by Chrysler tech help. Says a replacement ECM is required.
After putting $800 in for the PCM and now wanting another $1600 for the ECM, I am looking for some input as to the correctness of their repair process. And does it sound reasonable that the PCM/TCM and ECM failed at the same time??
Old 07-05-2012 | 11:49 AM
Blake Clark's Avatar
Very possible that something caused both to go haywire. They work in tandem. However, the ECM should be covered by the 5 yr 100k mile warranty. With the milage being that close to 100k, Id see if they could work with you.
ECM wont be cheap.
kf6cmp
05-02-2013 09:29 AM
Big Perm
12-18-2007 08:44 PM
jump
08-07-2006 12:33 PM
newtododge
03-25-2006 08:15 AM
Quick Reply: PCM to ECM issue
