Knee injury and feedback from 6.7 manual owners
Old 07-08-2007 | 08:00 PM
bigdave's Avatar
fade94, have you found the truck you want yet? If not where are you located, I might know where one is.
Old 07-08-2007 | 08:04 PM
03qclb5spd's Avatar
What is "floating" gears? Is that shifting without using the clutch, once rpms match trans/clutch speed it drops in gear??
Originally Posted by Hounddog
Who needs a manual with the new autos and exhaust brake.The manuals are a by gone era.
Some people like to shift their own gears, like me. GM probably lost customers by not offering a manual transmission on their current trucks.
Old 07-09-2007 | 08:06 AM
MikeyB's Avatar
[QUOTE=03qclb5spd;1589552]What is "floating" gears? Is that shifting without using the clutch, once rpms match trans/clutch speed it drops in gear??
[QUOTE]
That is correct.
MikeyB
Old 07-09-2007 | 08:10 AM
fade94's Avatar
Floating on a big rig is easy enough. But the smaller diesels take a little more coordination. On a big truck, you get the RPM and speed up. Then you let the RPM drop to the point it would be in the next higher gear and float it in. On the down shift, it's just the opposite. You pull into neutral and bump the RPM up to where they would be for the speed your going in the next lower gear. Tap the RPM up, let of the go peddle and float it down a gear. Takes practice, but it can be done.
I have driven the new 6 speed and it is way cool. More than likely will be going for it.
Old 07-09-2007 | 08:13 AM
fade94's Avatar
I'm north of Dallas, TX. The dealer will do a search for me once I get everything in place. I'm getting it from the flagship dealer for the MegaCab longbed conversion. They are going to get the stretch done, B&W hitch, Firestone RideRite bags, spray in bedliner. The issue has been finding a truck equiped the way I want it. Looking for a SLT with top of the line audio with GPS, tow hooks, light group, engine heater, 4.10 rear with auto trans. Would like the Patriot Blue but will go with a Silver as well.
Old 07-09-2007 | 02:29 PM
03qclb5spd's Avatar
That's what I do, but not often. Sometimes it floats as smooth as if I was using the clutch, other times it's a little more difficult but it still goes in. i've also downshifted by tapping the throttle up, but it's kind of pointless without an exhaust brake I think...which I do have, but not installed....not sure if I will put it on or not.
Diesel Demon
05-23-2007 11:04 AM
rockcrawler304
04-01-2007 11:25 PM
P.J
01-30-2006 10:33 PM
pogorules
03-05-2005 01:54 PM
