homemade intake horn
I know my sig is a 6.7 but I need to ask some 5.9er's about an afermarket plenum. I noticed that I gained 4psi of boost and my idle egt's are about 50° lower than stock. Also at 100mph with the edge turned up my temp was 1050°, so im happy there. But I noticed that the egt's fluctuate really fast and it climbed up to 1500° and just as soon as it does it drops once the truck catches up with the throttle. I will post some pics of it later but I know the truck pulls better especially on take off. My whole theory is that more air means more fuel has to be added so there will be a temporary gain until she levels out. Btw the intake is super smooth, i've just never experienced a new plenum, and advice will help and what alhave y'all heard or experienced
Thanks
Dayton
Thanks
Dayton
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
get more results being in the 5.9 section.
in reality you should not have seen any boost gain as boost is a measurement of restriction and with reduced restriction it would drop slightly. i can see a temp drop.
as with your theory more air = more fuel. unless you did turbo and fuel mods, it has not changed
ovrszd
24
04-23-2011 04:14 AM
yelloz28
29
07-27-2010 09:08 PM
1985cucv
16
04-20-2009 04:27 PM
OldSmokey
29
02-25-2008 10:06 AM
