Has anyone idled the 6.7 for extended time
Old 09-18-2007, 09:26 PM
dplenzig's Avatar
I was wondering if anyone has let their truck idle all night for example. I have a job where we have always done that with are previous trucks, but I heard the 6.7 should not be allowed to idle.
Let me know what you guys have experienced.
Daren
Old 09-18-2007, 10:57 PM
6.7megamax's Avatar
I think all night is going to be a stretch. I have let mine idle for about an hour and it was fine, however my dealer told me no longer then 25 min. I think the only way to find out is try and watch for the Cataylst 90% to come up.
Old 09-19-2007, 03:57 AM
UNOUNVIT's Avatar
Pulled a smooth one about a month ago and fell asleep left the truck running for atleast 6 hours!!!!!!!
Came out realised what i did jump in overhead read 75%, went for a 10 min drive and overhead came right back to 0. No problems!
Old 09-19-2007, 08:44 AM
fflarry's Avatar
5 hours at high idle with no problems.
Old 09-19-2007, 10:03 AM
Hired Gun's Avatar
3 hours this summer while irrigating tobacco. No problems at all. Left the ac on cold and read a diesel power magaziene and listened to playboy radio. Did this for at least 2 months on and off. Not once did it result in anything bad.
Old 09-19-2007, 10:14 AM
Swinco's Avatar
4 hours max then truck must go into regen mode. If the truck has idled for more than 4 hours, usually I have to take it to a dealership because it won't go into regen.
Old 09-19-2007, 02:23 PM
wreedCTD's Avatar
You should get high idle enabled and sleeping in it all night should not be a problem.
Old 09-19-2007, 02:24 PM
wreedCTD's Avatar
Are you sure you have all the latest flashes? I have heard nothing but good about the latest flashes.
Old 09-19-2007, 06:14 PM
eb290's Avatar
If you will notice Swinco has a Cab and Chassis. The pickup flashes do not work on the cab and chassis. I know, I had mine really screwed up when a dealer tried to put a flash on my truck, it was for a pickup. It took another dealer several days and many calls to Star to get things right. To my knowledge there are no flashes for the Cab and Chassis. Any flash needs to be checked with your VIN to make sure it is right. Any techs out there can correct me on that if I'm wrong. I've never idled mine overnight, but I have idled mine for longer than 4 hours at 900-1000 rpm with nothing showing up on the overhead. Actually did it today for about 5 hrs.
Old 09-19-2007, 11:50 PM
Dodge man's Avatar
Isn't that a little hard on the MPG?
Old 09-20-2007, 07:38 AM
eb290's Avatar
Yep, but sometimes when you are sitting at a rig waiting to get 65 joints of pipe unloaded and they aren't ready to take it, that's what happens. Me and three other trucks. That's OK, after the first hour, I get $50 an hour dentition time.
Old 09-20-2007, 01:49 PM
toupee's Avatar
eb290 - Are you a petroleum engineer?
Old 09-20-2007, 05:04 PM
eb290's Avatar
Not hardly, I'm a hotshot driver.
Old 09-20-2007, 08:41 PM
myfirsttruck's Avatar
Hey work - I have two Cab & Chassis and their is most certainly a flash as I have had both done. I will see if I can get the numbers.
Old 09-21-2007, 10:37 AM
Top's Younger Twin
Scotty's Avatar
Is there a TSB like on the previous engines to get the high idle enabled?
Found out the other day when I wanted to increase the idle for a faster warm up that the dealer did not enable it. If theres a TSB I can get it enabled without charge at any dealer. Any help is appreciated.
Scotty
Quick Reply: Has anyone idled the 6.7 for extended time
