greasing the front driveshaft
Do you need a special grease fitting to grease the front driveshaft on the 4x4? Will a standard grease gun work? Thanks for any input, tips.
Well if everything is stock , you may not be able to grease at all , until you replace the stock u-joints with aftermarket grease able joints , as much as I've seen anything for the last 20 yrs , came with sealed joints , and the rest of the drive train , all sealed , new definition to an old term , preventive maintainance = prevent you from maintaining .
As far as special fittings , yes , but that's just normal , about 3-4 fittings to do most .applications , right angle , needle & standard
cmp truck
0
06-09-2015 04:40 PM
TheMighty'67
03-30-2010 09:55 PM
hot tempered
07-02-2009 05:42 PM
PoorMansCat
04-22-2008 11:49 PM
tslewisz
10-24-2005 07:01 AM
