Engine making loud noise w/ jake brake switch on
When i have the truck iding with the jake brake/engine brake swith on the engine makes a louder knocking noise. It immediately quiets down when i turn the swtich off. Im wonderng if this is normal since i just got the truck from a private owner.
Location: This Nazi state of California 2nd home Gilbert AZ under God
Variable Gate turbo motor changing the vane position when you turn it on. Why I do not know, but think that it is spring loaded and when it turned on it move it out slightly maybe for response time(less distance to move when actuated)Maybe someone else has a better explanation. Maybe with the thing off it locked so that it does not move and when you turn it on it unlocks and moves it out slightly so the locking mechanism is unlocked and is ready for the motor to move it when really turned on by the ECM. Have not had to replace one yet in 140k so I have not had the chance to take one apart to see why
The EB can be used as a warm up feature for the engine. It will engage the EB at idle and even at high idle.. I use it all the time to get the engine up to temp faster.
The Variable Geometry Turbo doesn't use a spring IIRC. Its all positional servo controlled, ie the servo moves to precise positions based on voltage. The larger versions of the turbo use air actuated cylinders to do the same function.
mrcbmlasvegas
10-30-2011 12:27 PM
way up north
27
08-09-2007 07:07 AM
albrightfour
02-03-2007 10:54 AM
dws35
09-06-2006 06:27 PM
