Engine Light On
Engine Light On
I've barely put 350 miles on my 08' 6.7 and the engine light is coming on. Taking it to the dealership today to fix the problem, Anyone else having the same issue or suggestions.
The 6.7 seems to have more issues when new and will drop codes that the dealer has to reset. Most people report little or no drop in performance and some ignore the light after a few trips back to the dealer, not a recommendation but it does seem to happen.
Report back on what the dealer said the code was caused by.
It's happened to a lot of us. Don't let it bother you to much. I've only had to go back in once (knock on wood). My milage went up and haven't had it happen again.
Mine comes on constantly. The code that is set reads, "Turbo charger boost pressure not detected". Both dealer and I agree that replacing the turbo would only be a temporary fix until this emissions stuff is figured out. The truck drives fine regardless of whether the CEL is lit or not. I'll probably get tired of it eventually and push to have the turbo replaced, anyway.
2007.5 Dodge Ram 3500/6.7 CTD/SRW/SB/4X4/6-speed man/Big Horn Edition/16k Husky manual slider hitch
hang in there the more you go back it seems the better things get....I've had mine back in 8 times now....anything from recall, MIL lt.,new turbo x 2,oil leak from turbo #2...etc...etc...mine has been getting better fuel mileage and running great so hang in there dodge/cummins will get something figured out.....
Check engine light
Sorry to say but check engine light is common occurence my 07 with 8000 miles has been in shop for total of 32 days, dpf, turbo, engine rap, o2 sensor, this sensor, that sensor, and today check engine light is back on. Ive had all updates, and 12 mpg is does not make me so happy. Sorry...........
stratos201proxl
01-16-2014 11:04 AM
Joey-D
12-12-2011 12:52 PM
choppers555
10-16-2007 12:29 PM
Stevenc
12-28-2004 08:29 PM
