ECM Programming
ECM Programming
I have a bad ECM from the truck getting flooded. The dealership says I need a new one ($1700) because a used one already has a VIN burned into it and it won't take a flash. A guy sells used ones and says people buy used all the time ($600). Is there a way to get around that?
Unless you meant a 2010 ECM..
thats what i thought but when i hooked it up to witech it came up as a 2000 model year, then walked thru the process of reentring vin info and reprograming and every thing worked just fine. on gas vehicals its a whole different story. it could have been a vin miss read but thats what showed up when i pluged it in
Wow.. never would have thought you could do that with the change in processor speeds. I would think the PCM could be interchangeable not the ECM with the change from the VP44 pump to a 4 event injection, vin locked injection system..
You can contact Bob Wagner he helped get me a ECM for my 2000 dodge they are flashed by Marco at Mads electronics.
http://smartypower.com/new/contact.html
proaudiomaster
0
01-17-2013 11:29 PM
hdlivestock
19
01-05-2009 08:31 AM
jrussell
17
09-17-2007 06:38 PM
Ohio Joe
07-12-2004 12:13 PM
