Could it be this easy? I cannot confirm but.....
Someone on another site claims that you can put a simple straight pipe on your truck and put 400ohm resistors in the EGT plugs and the truck will run fine. Sounds like it may be a solution for a cheap DPF delete system. Someone with some resistors that already had a delete kit on their truck could try it to see if it works. I'm not gonna do it though. I was the guinea pig with the Rokktech crank sensor....
Just an idea.......
Just an idea.......
They now have you simply unplug the electrical connector to that box on the side of the trans and you also unhook the lines from it. You do not plug the holes on the box for some reason. Still gives me codes though.
Gypsyman, there you go. Try it and if it works you can sell them as a cheap kit to us....
buddy26
25
12-12-2008 10:17 PM
RacenutSB
06-07-2006 12:09 AM
