code scanner
I bought one at Walmart for $45. Works perfectly. The cheap model shows you the codes, including pending codes (problems that haven't set off the CEL yet) and lets you clear everything. It does not let you see freeze frame data or actual sensor readings.
Como4076
01-18-2008 10:19 AM
