07 Quad Cab 4x4 5.9 Cummins 6 speed manual fuel milage?
Old 05-24-2007 | 01:57 PM
reel adventure's Avatar
I know this has probally been discussed to death. This is my first post.
I am looking at a 07 quad cab 4x4 with the 5.9 CUMMINS with the 6 speed manual trans. 373 rear end.
What kind of fuel milage can I expect in the city and on the highway with this setup?
What are you guys getting? The truck is stock at this point. (brand new)
Thanks! Great site!
Old 05-24-2007 | 02:00 PM
Dieseldude4x4's Avatar
First thing you need to do is learn how to spell CUMMINS.................
Old 05-24-2007 | 02:10 PM
I stand corrected. lemme go back and fix it.
Lemme....is short for "let me"
Old 05-24-2007 | 02:29 PM
I understand the "lemme" part. Sorry to sound a little gruff but I hate it when I see that.....
I edited your title too. Thanks..........
Old 05-24-2007 | 02:31 PM
You can do a search on "mileage" too. May get you some quick results.
Old 05-24-2007 | 02:40 PM
packard8's Avatar
Thanks! Great site!
Welcome,
I have pretty much the same truck but with 2006 on the title. It just turned over 10K miles and the mileage has steadily improved to around 17-18 MPG highway (cruise control set @ 70) and around 14-15 MPG around town. Be aware that the G56 tranny does not have as tall an OD ratio as the older NV5600, so I run about 5 MPH slower than I did with my Ford 7.3 6 speed at the same RPM.
I recently towed a 2500 gal water tank about 200 miles for a friend (light weight, but pushed a lot of air) and averaged 15.5 MPG for the trip (loaded trailer up, empty trailer back and some running around totaled about 500 miles for the whole trip. About 1/3 of the distance was on twisty mountain roads at 25-35 MPH. They say the CTD takes 15K+ to fully break in get max mileage.
I'm happy so far, lots of pulling power when towing but I do keep reaching for 7th gear when running empty on the freeway
Old 05-24-2007 | 03:10 PM
tbarbee1's Avatar
Mine gets 14 all the time I drive fast and have 35" tires I'm probably not a good guinnea pig.
Old 05-24-2007 | 03:48 PM
Buckshotmckee's Avatar
Mileage on these Cummins are going to be all over the place. I get 19+ on trips, and average 16.5-18.5 combined town/highway. I only have 6k on the truck. I've noticed a difference in mileage depending on the fuel additive I run as well.
Old 05-24-2007 | 07:05 PM
mrblond's Avatar
I have got less then 2k miles on mine (same truck) 16.5 to 18.5 on average. But to do this kind of average I figure Im getting low 20s on the hwy but I have yet to verify this. The overhead btw shows some pretty good hwy numbers after reset, over 26mpg.
Old 05-28-2007 | 12:55 PM
mymaur's Avatar
I just bought a new 07 dually 2wd with the new engine and new 6 speed auto. I am anxious to see how it does.
Old 05-28-2007 | 01:03 PM
tbarbee1's Avatar
My overhead is consistantly 4-6 mpg off since I added the SC the mileage I posted was hand calculated. Be sure and check it both ways. It has 16,000mi on it and has been fairly consistant. I drove from Jordan Valley Oregon to SLC last weekend and about 522miles and drove between 75 and 80 the whole way and averaged 14.6.
Old 05-28-2007 | 01:13 PM
DR7seclx's Avatar
I get 20-22 on highway @58 mph and 18-20@68mph and 15-16@75mph and 18 in town, mine is a DRW 4x4, with about 11K on it now. I get 15 towing my 28' enclosed car trailer 11,000 LBS loaded with car and gear.
Old 05-28-2007 | 01:19 PM
DiEseLjunKy's Avatar
My overhead is consistently off by +2.5 mpg. As big of a spread in the numbers these kinds of threads typically generate I think it all depends on the truck. Some are just made perfect from the factory and get really good mileage easily. And the driver - some guys can keep their foot out of it and some can't. If you get 18mpg out of a stock truck be happy with that and consider yourself very lucky.
Old 05-31-2007 | 05:11 PM
ridofpwrstroke's Avatar
I have an 07 same as quote above. These mpg's are with a gear vendors overdrive. At 65 I was getting 16.5 without GV, on it would jump to 20. 70 mph was 14.6 without and 18.8 GV on. 75 I get around 17. I tow 16,000 I get 10-11mpg max. I dont see 15mpg towing 11,000lbs. This is a dually. Expect 1 to maybe 1.5mpg better.
89dieselkong
07-27-2010 10:55 AM
06Cummins
17
04-05-2008 11:03 AM
V.R.Wheeler
08-04-2007 01:00 PM
pwrtripls1
12-20-2005 04:51 PM
Quick Reply: 07 Quad Cab 4x4 5.9 Cummins 6 speed manual fuel milage?
