Winter fronts .....
Old 01-10-2005 | 09:03 PM
brownpj's Avatar
Winter fronts .....
do they help any at all?
I live in nothern Wisconsin about 10 minutes from my work. I just barely start getting heat about the time I get to work. The needle just barely off 140 when I get there. Do those winter fronts do any good?
Old 01-10-2005 | 10:52 PM
SuperGewl's Avatar
You need one real bad and yes they help alot. There are some pics on my web page of the DC one.
Old 01-11-2005 | 06:51 PM
Rob's Red Ram's Avatar
Thumbs up winter front
brownpj,I have the mopar cold front on mine and it definetly make a differance.Warms up faster and stays warm even in heavy traffic.Here's a pic.
Old 01-11-2005 | 07:52 PM
coobie's Avatar
Re: Winter fronts .....
They work GREAT.I live in Michigan,had mine on about 15 months.Noticeable difference in Cab temps with the winterfront.Mopar winter front is hard to beat IMHO.coobie
Old 01-11-2005 | 08:15 PM
Geico266's Avatar
I'm sure they work good, but there is no air for the trans, oil, or PS cooler. Is this a problem or am I just too worried about overheating?
Old 01-11-2005 | 08:31 PM
coobie's Avatar
No problems,I am running the BD X-moniter in my truck.I usally close all the flaps on my Mopar winterfront when temps are below 15-20 degrees.I open the flaps when the temps rise.I installed mine in late Dec.My tranny temps run 168-172 degrees with all the flaps closed at 15 degrees.coobie
Old 01-11-2005 | 09:36 PM
Whitmore's Avatar
Cold fronts work very well, on my 01 I monitor temp at the air horn (its for my ram air system) anyway there is about a 40* difference when cold fronts are on, optimum air temp at the horn is 70-90* and if you can maintain that you will actually gain on your effeciency. There are other bennifits like having the all mighty cummins up to temp so any fuel will flash out of your oil, fuel will get into your oil when the motor is cold and needs to be flashed off. I recently put Lund cold fronts on my wifes 04.5 and it warms up a heck of a lot faster now,
Dont worry about overheating, a diesel motor only uses 20% of its cooling capacity during normal driving, once when summer hit us overnight it got up to 65* and with my cold fronts still on the fan still never came on.
Cheers, Kevin
Old 01-11-2005 | 10:00 PM
AKram's Avatar
a must in cold temps
Old 01-12-2005 | 08:22 AM
Geico266's Avatar
I'm getting one then. The cardboard thing scares me. I already had a fan fail and come apart doing about $700 in damage.
How much did you pay for the winter front?
Old 01-12-2005 | 10:17 AM
SuperGewl's Avatar
They are about $100 from DC.
Old 01-12-2005 | 12:49 PM
Whitmore's Avatar
Lunds are like 85 from NAPA
Old 01-12-2005 | 11:49 PM
N.Johnson's Avatar
Cheers, Kevin
This man knows what he's talking about . Attention all diesel newbie commuter truck/short trippers. Words of dirty fingernails ...... Your cummins diesel is a work engine so drive it differently. No more short cold trips, yah yah how inconvienent.... too bad. Take the wifes car or drive your motor till it reaches operating temps. By the way lets not snivel about ticking/knocking till you put a ton in that bed and drive up a six percent grade. Then and only then will you appreciate that sweet engine. By DESIGN this motor can work 24/7 at peak rpms. Think about it or drive a gasser....rant over
Old 01-13-2005 | 01:07 AM
RamRunner's Avatar
Anyone have the part number handy for the Mopar winter front from the previous posts that everyone seems to be so satisfied with?
Old 01-13-2005 | 04:33 AM
coobie's Avatar
Mopar winter front part #82208646 coobie
Old 01-13-2005 | 10:43 AM
Whitmore's Avatar
Thank you sir!!! Just do it baby
Quick Reply: Winter fronts .....
