Winter bed weight ideas
Old 10-24-2009, 04:54 PM
Rpainter's Avatar
I put a concrete gabion from work. It is a small one I think 5 or 6 cu ft of concrete about 6 to 800 lbs
Old 10-24-2009, 05:27 PM
JP-4.5's Avatar
I put mine in 4wd and go..
Old 10-24-2009, 06:51 PM
billie's Avatar
^^me too.
Old 10-24-2009, 07:24 PM
Rpainter's Avatar
now what is the fun in that??
Old 10-24-2009, 07:33 PM
zx14on2's Avatar
i have put 700-800 lbs of salt bags in the back, then u can use them for the water softener in the spring-summer...but i worry about them splitting open. has not happened yet (knock on wood)
Old 10-24-2009, 08:22 PM
John Halter's Avatar
Location: somewhere in northwestern ohio....Mansfield, Oh
20 posts and not one cement bed liner , the man claimed it was great in the snow I recall .
Old 10-25-2009, 06:46 PM
Dynocon's Avatar
The father-in -Law also does the salt trick. Works great for him.
Old 10-25-2009, 08:54 PM
iaddiesel's Avatar
Originally Posted by 15 Digger
Where do you live? near me if you stop your pickup 4 or 5 Mexicans will jump in looking for work lol.
Not far from northern VA I guess I could swing by a 7-11 and do the same.
Old 10-25-2009, 08:58 PM
iaddiesel's Avatar
Thats a thought, I may do that, it's not like I need it that toften where I live, I just was thinking this winter may bring more snow, and my truck id crap in 2wd, even in wet grass on a hill, and yes I can use 4wd, but I would like to save it for last resort, especially at higher speeds not have to use it.
Old 10-25-2009, 11:05 PM
raymond21's Avatar
I just can't resist! Here's the DTR recommended way.
https://www.dieseltruckresource.com/...1.html?t=42441
Sorry, I just had to do it!
Old 10-26-2009, 09:51 AM
Grit Dog's Avatar
Tried that once here. D@mn truck was overloaded before I even knew what happened!
So I started driving south real fast! The smart ones caught on and bailed! Kept that up until I had the right amount of weight! Problem is if you want 800lbs in the bead you gotta carry 8 of 'em!
Old 10-26-2009, 10:22 AM
Guardrail's Avatar
I guess in a few years when the bed of your truck rots out, you'll know why.
Old 10-26-2009, 12:39 PM
klx650a2's Avatar
I used a 4 foot chunk of 1 foot wide steel I-beam from the main support of a house. I drilled a hole in the middle, put 1" all thread and filled it with concrete. With the all thread I could bolt it to the cross-member of the truck and had some good weight and it never moved. Man it was heavy, it was all I could do to slide it in the truck myself
Old 10-26-2009, 01:12 PM
DBLR's Avatar
A few bales of straw soaked with water, let them freeze and you have your weight for traction and yet easily removable during the winter if needed.
Old 10-26-2009, 04:14 PM
patdaly's Avatar
HAH! I made both you and John suggest it.
Now, THAT'S self control!
Quick Reply: Winter bed weight ideas
