White smoke at idle
White smoke at idle
Hello, This is my first time so if I mess it up sorry. I have an 03 dodge 5.9 that has white smoke when idling and more black smoke than usual during acceleration. Fuel milage down. Had it in dealership for a week they replaced #3 & # 5 injector and did not help. Need help I have an edge chip & AFE air filter. thanks
sounds like they missed a bad injector you can take it back and argue with they about it or you can check to see if there is a white smoke tsb for that year if not time for aftermarket sticks
Keep an eye on your oil level. I'd take it back to the dealer like Rpainter said. Try running somes Howes in one tank and a quart of 2 stroke in the next tank. Basically cleaning up one tank and lubing up the next. I think the ULSD is reaking havoc on everyones injectors.
I had white smoke as well, took the truck in to the dealer. They did the ECM flash for white smoke, but come the next day, guess what
? no different!
Oil level has been normal thus far, only other thing is some what of a tick once in a while, but figured it is a diesel, it doesn't run quiet. I am kind of lost on this one.
? no different!
Took it to Cummins had them work on it said nedded other 4 injectors picked it up friday 8/4/07 drove it 1 mile smoked so bad I took it back and they said they couldn't work on it till monday every body to busy. Feel like I am getting the shaft from the big C!
Isn't that the truth... Even harder yet is finding a decent mechanic with strong diesel background who will not rape you to do work.
Mine had a little stumble to it today on startup, not much white smoke though, and oil level seems to be same as it has been...
why do I feel like I need to do a lot of reading on replacing injectors...
recone5
11-05-2008 10:26 AM
RJOS
16
09-03-2007 09:19 PM
BuildingBoost
03-25-2007 07:46 PM
BlackSheep5
11-27-2006 07:52 PM
