White smoke galore now and back firing....
Old 02-06-2009 | 01:17 PM
sallyman1's Avatar
I think i foigured out now i have a bad injector. remember i said truck used to stumble/vibrate around 1800 rpm under load? now smoke is white all the time and black and whiteon the highway. i have had my edge totally unhooked for a while now. i think a injector is stuck open. tons of white smoke in town and its rough miss. should i do all 6 injectors? anything else to check?
if i do them what will i need for tools/sockets? injectors,valve cover gaskets,ful o rings, fuel tubes?etc.....
might as well do a valve set also. what do i need for tools? any special allan or torx or hex sockets?bent wrenches etc...
Old 02-06-2009 | 02:20 PM
sallyman1's Avatar
ttt. also truck idles around 6-7000 psi rail pressure. when i rev her up in neutral i get 10-12000 psi rail pressure briefly. is this normal for a sticky injector?
Old 02-06-2009 | 03:48 PM
Spooler's Avatar
Not good. Don't run it or you will risk melting a piston.
Old 02-06-2009 | 03:49 PM
sallyman1's Avatar
what is it? sticky injector/fca or is that 6-7000 psi idling normal?
Old 02-09-2009 | 02:06 PM
DBLR's Avatar
Sallyman,
I thought you went to school to lean how to work on diesel engines and become a diesel mechanic?
Old 02-09-2009 | 02:32 PM
homewrecker's Avatar
Old 02-09-2009 | 09:27 PM
sallyman1's Avatar
lol. why am i wrong? what else can it be?
diesel-medic
08-17-2015 09:03 PM
Hoss
03-24-2013 06:32 AM
stacked07
02-07-2009 08:54 AM
Timmay2
02-13-2006 08:51 PM
Quick Reply: White smoke galore now and back firing....
