white smoke from exhaust
where are you? whats the temp? how much white smoke?
I bleive there is a flash for white smoke on startup. maybe call the dodge dealer and ask about it. if you step on the gas while driving, do you see white smoke at all?
this has been talked about a lot, and here are some possibilities- 1. completely normal, when truck is cold 2. might want to look into white smoke/cold start tsb/re-flash 3. injector issue, might try running a good fuel additive and see if anything changes, or if still under warranty, have dealer check injectors- there are people who have experienced similar symptoms, who found that their injectors were leaking down.
recone5
11-05-2008 10:26 AM
RJOS
16
09-03-2007 09:19 PM
BuildingBoost
03-25-2007 07:46 PM
BlackSheep5
11-27-2006 07:52 PM
