While installing injectors I broke this little plastic collar
Old 08-08-2013, 05:43 PM
avantidude's Avatar
Ok while pulling up the injector I broke th little plastic collar on the rocker arm, I have all the pieces but is this necessary?
Old 08-08-2013, 08:26 PM
Spooler's Avatar
It's common, you have to replace the rocker to get that piece. Talk with Jeff at maumau diesel. Great guy.
Old 08-09-2013, 04:50 PM
avantidude's Avatar
Can I run it without it?
Old 08-09-2013, 08:26 PM
Spooler's Avatar
Noop, you need it or you may damage the stem of the valve.
Old 08-22-2013, 08:14 AM
Hintonc393's Avatar
I ran mine with out that thing for months. The older S60 driptroits had an issue where the spring steel keepers would fall off or wear through, only in a few cases have I seen them let the button come off. I did replace it with a new one. And yes I did have to buy the rocker arm to get it. I did reuse my old rocker arm and button so the wear pattern never changed. Thinking back on it I don't know how they don't fall off, I guess its the oil film holding it in place. Valves don't just shut because the cam wants it to, I have seen high speed footage of valves in operation where they will bounce well after the rocker arm is off of the valve.
Old 08-22-2013, 01:14 PM
pdogg's Avatar
I'm trying to figure out what plastic piece you're talking about, I recently pulled my injectors and waiting to get them back..
I didn't see anything resembling a plastic collar when in there.
Any pics?
Old 08-22-2013, 02:27 PM
Hintonc393's Avatar
It holds the little metal button to the end of the intake rocker arm.
Old 08-22-2013, 06:04 PM
pdogg's Avatar
Am I insane, but don't you remove the exhaust rocker to pull injectors?
Old 08-22-2013, 06:54 PM
StealthDiesel's Avatar
^^^Yes you do, but what does that have to do with the original poster's issue.
For everyone else, be gentle with the rocker arms when you are working on them.
Old 08-23-2013, 11:58 AM
Hintonc393's Avatar
You only NEED to remove the exhaust rocker to replace the injector. I broke mine when I was prying on the injector to pull it out. As it popped loose it knocked into the intake rocker arm breaking the little plastic keeper.
hamilton71801
10-24-2007 04:42 PM
displacedtexan
07-08-2007 12:16 PM
andyr354
07-08-2007 07:28 AM
ChrisLib
01-19-2005 05:57 PM
1ST GEN.
10-05-2002 08:53 AM
Quick Reply: While installing injectors I broke this little plastic collar
