Where is my antifreeze going?????
Ive been loosing antifreeze since the first day. I cant find any leaks externaly, so im wondering if its going in the engine. I know i can do a pressure test, but would a oil test tell me if there was antifreeze in the oil? If so, does that mean bad head gasket?
anyone else had this same prob.
Im guessing your oil isnt all milky or anything eh? If your losing a substantial amount into your oil it could be as bad as a cracked head. Tho im not familiar enough to say. its not smoking white is it? You could be burning the coolant off through a head gasket leak as well. your right by starting with the oil sample tho.
to see if its getting to compression take your rad cap off when the truck is cool and shut down. Top the fluid up until you can see it. Start the machine and run it at high idle, you should see bubbles for five or ten minutes at which point it should smooth out as all the air gets out and the thermostat opens. If its bubbling like crazy and blowing everywere you could be getting compression into your coolant.
You can also get a pressure tester. Little hand pump and an adapter to replace your rad cap. Screw it on and pump it up, it should hold pressure. If its not you have a leak. Should try it with the engine cold and hot, incase a crack is expanding with the heat to eitehr open or close.
It doesnt matter whether its head gasket or head itself at this point as either way you have to pull the head. You just need to be sure that it is infact getting into the cylinders.
When the time comes to take it apart you'll be able to tell if the head gasket has been leaking as you should see a break in the gasket. If you dont you can get the head pressure tested.
Im sure someone else will have some ideas as well.
Like Spooler said : Check the overflow hose. I was wondering where my was going then found it was a slow drip under the bottom of the hose. Not enough to see it easily. I put on a clamp, and problem solved.
dodgediesel
09-23-2007 03:27 AM
