Where to install oil pressure sending unit?
I don't have a pic, but....
I installed mine right on top of the oil filter mount; there's an 1/8" NPT fitting there that is intended to be used as the oil pressure test port. Also, there's plenty of room for it!
HTH
Tony
HTH
Tony
there is also a pair of M10x1.0 orb ports/plugs on the the left side of the engine that come off the main lube oil gallery/cam bearings... i have mine there.. there is a ~2-3 psi pressure differential from there to the filter pad...
one plug is above ecm, one is below/behind cp3 [also on same gallery is factory switch and extra m14x1.5 port blocked by fuel filter assembly/bracket]
GlennRMK
05-24-2007 10:46 PM
fourdawgn1978
04-19-2006 05:27 PM
Dieseldude4x4
10-24-2005 09:12 AM
