Where is egr valve on my 2004.5?running hot with edge
Old 03-04-2009 | 11:48 AM
sallyman1's Avatar
ive been having a argument emailing back and forth with a edge tech. he says reason why my 2004.5 has high egts with edge juice is because he said my 2004.5 has egr. i said just the 3rd stage injection event and the cat right? he said no. cat has nothing to do with it. he said and i quote
"The EGR is not the CAT, the EGR system is on the motor, and it just re circulates the exhaust gases back through the motor. The EGR system combines exhaust gasses with fresh air in an effort to reduce emissions. "
Where is my egr valve located on my engine? There has to be this valve because edge knows. I also told him i see 950-1000 egt on highway empty at 100 km/hour and he said thats normal or" in check" with what it should be. he also said when i pass vehicles on highway empty at 130 km/hour, that i should easily see 1500 F and that i cannot hurt piston because thats the temp of gases not piston.
LOL lol....is he right?
Old 03-04-2009 | 11:56 AM
GlennRMK's Avatar
EDGE person doesn't know anything
There is no EGR on the 5.9s that I'm aware off. Only on the 6.7s.
Something is weird because your EGTs are way high
Send the EDGE back to them to get fixed. Buy a Smarty and sell the EDGE.
Just my 2 cents.
Old 03-04-2009 | 11:57 AM
CTD NUT's Avatar
Empty at 130 KM makes no sense with just a Juice. I would certainly not find that acceptable to have 1500* EGT at a steady state cruise of 130 KM!!
And the EGR's are on the 07.5 and up 6.7's. Your 04.5 does not have one.
Old 03-04-2009 | 12:24 PM
johnh's Avatar
check for boost leaks..... low boost will cause higher than normal EGT's
Old 03-04-2009 | 12:38 PM
CamperAndy's Avatar
His engine is in pieces as he said he has a holed piston.
Old 03-04-2009 | 07:54 PM
pullin hard's Avatar
sallyman1 : you need a better turbo
no egr, edge must not understand you.
my egts while towing say 7000lbs, up a hill, never seem to go over 900 with my 66.i am never really pushing it, and i always turn down fueling boxes when towing.i usually sit around 750-800 egt on the highway doing about 70mph empty.
Old 03-04-2009 | 09:17 PM
sallyman1's Avatar
maybe turbo but i can hit 45 psi boost easily
Old 03-04-2009 | 09:18 PM
sallyman1's Avatar
we will see my numbers with my new engine
whosdunit
02-16-2019 04:07 PM
MOJO1
08-04-2009 06:28 PM
Strjock81
16
12-12-2007 09:53 AM
edwinsmith
04-14-2006 03:53 PM
duallydave
08-07-2005 09:38 PM
Quick Reply: Where is egr valve on my 2004.5?running hot with edge
