Wheel Stud ???
Old 05-20-2009 | 09:24 AM
Ceno's Avatar
Wheel Stud ???
Does anyone know if the wheel studs on an 03 2500 would be the same as an 01.5. I broke 3 and a buddy has 3 or 4 for a 2nd gen but we don't know if they are the same...
Thanks in advance
Chris
Old 05-20-2009 | 03:04 PM
Ceno's Avatar
No one knows???
Old 05-20-2009 | 07:49 PM
homewrecker's Avatar
Take a lug nut from yours and screw it onto his.I'm pretty sure they are both 9/16 but the length is where I'm not sure.
Old 05-21-2009 | 09:09 AM
enafzige's Avatar
I think they're both 9/16 as well.
The bigger question...do you know why they broke? Are you running the factory wheels or aftermarket?
--Eric
Old 05-21-2009 | 09:59 AM
Ceno's Avatar
Running H2s... broke them taking them off. The guy at a local diesel performance shop said he's broken 5 or 6 in the last 3 weeks all on 3rd gens oh well....
Old 05-21-2009 | 02:11 PM
enafzige's Avatar
The reason I ask, is that with most wheels, other than the OEMs that came on the truck, you will have this problem eventually.
If you remove your wheel, you'll notice that on some of the studs, there are little spur retaining washers at the base of the stud, up against the rotor. The OEM wheels are clearanced around this area...and alot of other wheels aren't.
I broke 3 studs before I learned this. If these were not removed from your truck, take these spur washers off, and the problem should be fixed.
--Eric
Old 05-21-2009 | 10:07 PM
Ceno's Avatar
Well the dealer is no help... they looked up the stud and said "That is the most expensive wheel stud I have ever seen" $18 EACH Then I had him look up and 01 and he said "They are totally differant part numbers, you can't use this one on an 03" Now the question is, is these anywhere other then the dealer I can get these? I tried AutoZone and Advance Auto and nothing......
Old 05-22-2009 | 01:13 AM
kokalit's Avatar
$10.48 at this place... not including shipping charges.
http://www.moparpartsamerica.com/par...layCatalogid=0
and
$9.60 at this place... not including shipping charges.
https://www.dodgeparts.com/oe_parts_...575e804454e791
74dart
07-07-2007 07:58 PM
robwil
04-17-2007 09:07 AM
mogpuller
11-28-2006 05:35 PM
Tommy93w350
12-05-2004 08:27 PM
Quick Reply: Wheel Stud ???
