Whats fleetguard # for 7 micron fuel filter?
I have a 2004.5 ram diesel with stock filter housing but intank lift pump. i usually run 10 micron. whats some numbers for 7 micron filters that i can run?
What's Fleetguard # for 7 micron filter?
I just go to Cummins and buy (by the case) the replacement 7 micron fuel filter elements. There's no other name on them other than Cummins. They're between $11.95 and $13.95 each depending on which Cummins shop you visit.
Yeah.. DON'T RUN IT!!!... That filter is 10 microns nominal (50% efficient).. OE specs 7 microns absolute (98.7% efficient).
There are only two filters that meet OE spec, OE and the Baldwin PF7977.
me. i just put one in today. got it from oreillys. theres a napa not too far. do they stock what we need for our trucks? thanks for the education
stroker101,
Go to http://www.baldwinfilter.com/ put in your zip and it will show you the nearest dealer.
stroker101,
should i change it out? i just put it in today. looking for advice from you more knowledgeable CTD owners. thanks again
I think you will be Ok for a few days until you get a better filter. Do you have a Cummins shop near by that you can call to see if they carry the Fleetguard Stratapore FS19856 Premium Fuel Filter as its a lot better then any Wix/Napa fuel filter. If no Cummins dealer is near by then go to Geno's garage on line at: http://www.genosgarage.com/ then on the link for Dodge Products.
