What size socket needed for front hubs?
dont have it apart yet still waiting for parts but what size socket holds the front hub bearing unit on?
Location: In Oroville, Ca., same house for past 46 yrs!
If your's is like mine, you can't change the bearings... you change out the whole hub assembly.
I hope they got their act together on the 2004's on up in the lighter weight trucks (3/4 ton vs 1 ton units)
You will need a 1 11/16 in a 3/4 drive. Loosen the nut before you lift the truck. You may need a breaker bar and an extension on the bar.
Like FastTaco I used a 1 3/4 socket.
91oldranchtruck
01-31-2011 09:45 AM
Scott03HO
06-01-2005 03:31 PM
Rob_OBX
03-02-2004 11:27 AM
