What make 6 sp manual gearbox in early '04
Old 03-04-2015 | 07:16 AM
Steve-l's Avatar
My 6 speed has an all cast iron case. It is very stout and has a 1 1/4" diameter pilot shaft. What brand is it and what oil should I be using in it. Also what oil should be used in the transfer case.
Old 03-04-2015 | 11:34 AM
MikeyB's Avatar
It's a New Venture NV-5600. Takes a synchromesh fluid (5w-30). Popular brands are Pennzoil Synchromesh Fluid, Redline MTL and Amsoil MTF.
Transfer case takes ATF+4.
Old 03-04-2015 | 01:35 PM
Steve-l's Avatar
Thanks MikeyB. I read ATF+4 in the Owner's Manual for the transfer case, but only a Dodge part number for the gearbox.
Old 03-05-2015 | 01:54 AM
E.Roy's Avatar
I like the Redline Oil Manual Transmission Fluids because they are GL-4 rated. GL-5 is usually too slick for synchros. Check their website for weight recommendations, lean to the heavy side, since heavy use burns those 6 speeds up
Old 03-05-2015 | 05:56 AM
Steve-l's Avatar
Thanks for the tips. Although oil is certainly important on syncro life, driving habits and gear shifting skill is FAR more important. If there is no speed difference between shaft speeds, the syncros are not asked to do work.
CACalomino
20
06-26-2007 07:19 PM
DieselJoe
04-03-2006 12:05 PM
mooseman
12-09-2005 07:34 PM
Bikinaz
01-24-2004 08:39 AM
Quick Reply: What make 6 sp manual gearbox in early '04
