What Guages to get?
Old 11-07-2007 | 06:40 PM
firecrazy720's Avatar
What Guages to get?
I am looking to get guages and wanted to get some opinions on what other people are using.
Old 11-07-2007 | 06:59 PM
erik_herrling's Avatar
I got the DiPricol EGT, Boost (35lb) and Trans Temp Gauge and mounted them on a dash pod about two weeks ago. Everything works fine and looks great. I got mine from DieselManor and also got their Transmission Temperature line adapter. Total cost was less than $500 including shipping. They even threw in the boost bolt for free.
Old 11-07-2007 | 07:04 PM
Is anyone using the quadzilla commander and what kinda deal can I get ?
Old 11-08-2007 | 10:27 AM
j's Avatar
j
gonna do dipricols myself later this year. mainly because they match the stock gauges and i like fact that they have a "red zone" on the gauge face itself telling you when you are about to exceed temp or drop fuel press too low. easy on the eye's when all you have to do is glance at them to see how close to the red you are. i'm going with pyro, 60lb boost and fuel press.
Old 11-08-2007 | 11:00 AM
PhilR's Avatar
I'm not towing on a regular basis, so a transmission temperature gauge isn't a priority. I went with the two most important gauges in one, EGT and boost. I really like having the two gauges in an optimal location and still keeping the grab handle. The Quad fuel/rail pressure gauge set up is really cheap and recommended if you start adding any mods that increase fueling demands.
Old 11-08-2007 | 01:06 PM
jrussell's Avatar
Yep, love the SPA's!
Old 11-08-2007 | 01:59 PM
Chopper_Bob's Avatar
DiProcol's are spot on to the factory look. Issopro's are less expensive and pretty close to the factory look. I understand that both are good. I myself am planning on buying the DiProcol's this weekend.
Old 11-08-2007 | 02:22 PM
06Cummins's Avatar
ive had isspros(on my old ferd) and Di-Pricols on this truck...love my Di-Pricols besides that pesky purplish ring around the boost gauge at night..heres a night pic i took for someone a while back..its still kinda hard to see bc the camera didnt pic up the lighting too well..but the purple rings arond the center of the gauge arent as bad as the pic makes them out to be..its really only noticable on my boost gauge while driving..hope it helps your decision
Old 11-08-2007 | 03:52 PM
nitis's Avatar
those SPA gauges are sick then I got sick when I saw what they cost
4-500 each ughhhhh
Old 11-08-2007 | 03:56 PM
jrussell's Avatar
4-500 each ughhhhh
You can get them for around $200-250 new from BimmerWorld.
Old 11-08-2007 | 04:35 PM
booman70's Avatar
ISSPRO best match to stock
Old 11-08-2007 | 04:49 PM
CD in NM's Avatar
I installed the ISSPRO's - EGT, Boost, and Fuel Pressure and the DiPricol Rail Pressure. Had ISSPRO made a Rail Pressure gauge I would have intalled it. The ISSPRO gauges resemble the factory stock gauges over the DiPricol. I gave up my entry handle to a 3 gauege pillar and mounted the Rail Pressure gauge in a single bullet pod next to (outby) the bottm pillar gauge. That is a dead spot anyway so filling it up with a gauge just made sense. Didn't really need a tranny temp gauge with the 6-speed, although they do make the Fast Coolers for your tranny so you could install a tranny temp too.
CD
Old 11-08-2007 | 05:11 PM
GEN_X's Avatar
As soon as this is available for the dodges this is what iam getteing
http://v8tvshow.com/content/view/441/1
http://www.magden.us/applications.html
Old 11-08-2007 | 06:58 PM
enafzige's Avatar
Man, that is awesome! Any idea on what a system like that would cost? The capabilities that would open up would be almost endless. --Eric
Old 11-08-2007 | 07:15 PM
moneytlks01's Avatar
just finished the video, pretty awesome if you ask me!
