What is good additive to diesel fuel
Old 04-22-2013 | 05:36 AM
dogger's Avatar
Stanadyne Lubricity formula
Personally I like Stanadyne lubricity formula. The Ultra Low Sulfur Diesel of today does not lubricate as well as the diesel of 10 years ago or the Low Sulfur Diesel. ATF has some undesirable additives that may not be good for your CR diesel.
Definitely upgrade your filtration. Even Cummins decided the old 10 micron filters of yesteryear were not good enough for the early CR. Now they recommend 7 micron filtration. I'm using 2 micron for my vehicle.
Take a look at this research project: http://http://www.dieselplace.com/fo...y-results.html . Is it gospel, probably not, but at least there may be some good information contained.
Good luck,............dogger
Old 04-28-2013 | 05:55 PM
Jer-ah's Avatar
i use a john deere diesel additive in my 03 5.9L.
Old 05-01-2013 | 04:06 AM
mj007's Avatar
Originally Posted by dieselfreak21
Ive run schaffers They run quieter and starts easier. Additive alone is only part of the solution better filtration is a must. Factory doesn't cut it.
Ditto on the Schaeffers
7273rogers
12-16-2012 09:59 AM
04ctd
01-23-2005 06:12 PM
Chrisf
08-22-2003 12:03 PM
MARKY MARK
11-19-2002 09:37 PM
Quick Reply: What is good additive to diesel fuel
