what fluid is everyone using
Old 08-01-2008 | 12:36 PM
htech's Avatar
what fluid is everyone using for front diffs, rear diffs, and transfer cases? i know dodge says to used synthetic 75/90 for the diffs and add an additive of theirs if you have a limited slip. and the mopar atf +4 for the tcase but what are you guys using? royal purple?
Old 08-01-2008 | 12:39 PM
06RAM2500's Avatar
Royal Purple ATF+4 in the t-case, 75-90 in the diffs. It has a limited slip additive mixed in, so no need to add any.
Old 08-01-2008 | 04:31 PM
timcasbolt's Avatar
You don't need any type of additive in an AAM because there aren't any clutches. I used Red Line last time, and put Mopar ATF+4 in the transfer case.
Old 08-01-2008 | 04:49 PM
Dynocon's Avatar
Valvoline synthetic.
Old 08-01-2008 | 04:58 PM
Roperteacher's Avatar
Amsoil 75/110 . I tow heavy
Old 08-01-2008 | 06:04 PM
CD in NM's Avatar
Amsoil 75w140 in diffs, Amsoil ATF in tranny and xfer case. HOT roads and heavy loads.
CD
Old 08-01-2008 | 06:25 PM
OOPS's Avatar
Amsoil in the diffs. No where in my FSM does it call for an additive in the rear diff., it is a gear type LSD not a clutch type.
Old 08-01-2008 | 10:35 PM
BWdiver's Avatar
Valvaline premium blue in motor, Valvaline syn in the auto, Mopar ATF+4 in trans case and Royal Purle 75-90 in diffs.
Old 08-01-2008 | 11:42 PM
DUKCALN's Avatar
There is only one, AMSOIL.
Old 08-01-2008 | 11:46 PM
rjm022's Avatar
amsoil- use it in the diffs, tranny, brakes,power steering, engine and transfer case.
Old 08-02-2008 | 05:46 AM
Hounddog's Avatar
www.amsoil.com There are many quality fliuds out there.
Old 08-02-2008 | 05:59 AM
eddiebob's Avatar
Redline 75-90 in the differential. Lots of guys where I work use Royal Purple. Ed B
Old 08-02-2008 | 06:56 AM
JP-4.5's Avatar
Amsoil Severe Gear(75/90) in diffs, Amsoil ATF in tranny and xfer case.
I also use..
Amsoil SAE 15W-40 Synthetic Heavy Duty Diesel in the motor.
Old 08-02-2008 | 11:00 PM
dwo3rd's Avatar
Just use what is recommended by amsoil and don't worry about it anymore.
hilclmr2
04-11-2007 03:49 PM
morkable
17
01-09-2007 09:12 AM
WACTD
17
03-30-2006 12:15 AM
Greguw
23
10-30-2005 12:14 AM
HappyGA
22
02-26-2005 08:00 AM
Quick Reply: what fluid is everyone using
