what additives with the new diesel??
Old 11-15-2007 | 09:06 PM
cssnider's Avatar
hey guys! since they have changed the diesel for this year, what additives are you guys using with you fuel?
I've heard that the Lucas diesel additive is something that you should use every time you refill your tank.
Need a little advice....
Old 11-15-2007 | 11:12 PM
woodrep's Avatar
Lucas is good, I ran it for a while, but now I run TCW-3 2 stroke ashless in mine. Quiets the engine clatter and runs like a well oiled machine! 1oz. to 1 gallon of fuel is the common ratio.
Wood
Old 11-15-2007 | 11:40 PM
DaveB.inVa's Avatar
Check this out
http://dieselplace.com/forum/showthread.php?t=177728
It rates the Lucas additive as having slightly less lubricity than ULSD alone.
I run Power Service which came in #10 on the list. I'm laid up right now and not driving but I intend to start running TCW3 2 stroke from Walmart along with Power Service on the next fill up.
Old 11-16-2007 | 01:32 AM
cgmorgan06's Avatar
Check out BG prod diesel fuel conditioner, I really like their products. It is so concentrated that 1 gallon of fuel conditioner treats something like 2500 gallons of diesel!
Old 11-16-2007 | 03:21 AM
na4now's Avatar
I run 2 stroke every tank, and diesel clean every three or four.
Old 11-16-2007 | 07:49 AM
CD in NM's Avatar
I'm running the Opti Lube XPD and their summer blend. Thought I'd give their stuff a try. I had been running PS/MMO.
CD
Old 11-16-2007 | 08:31 AM
JohnInNH's Avatar
CA-40 + Howes Meaner Cleaner, + PS or howes anti jell (in winter) + 2 stroke... I mix it all in a quart bottle and it treats 60 gallons.
Old 11-16-2007 | 08:43 AM
ratlratl's Avatar
MMMmmmm.... Grits!!
Started with Lucas, then went to PS Diesel Kleen, and now running 2-stroke oil. 1 Qt to a full tank. Like the last best! Made me a believer.
Chris
Old 11-16-2007 | 09:19 AM
Roperteacher's Avatar
I am running the Opti Lube Summer blend and have run a tank or two of the XPD I am seeing excellent results. I am in the process of really testing it as we speak...
Old 11-16-2007 | 02:50 PM
cssnider's Avatar
sounds like some good advice guys....I appreciate it
Old 11-16-2007 | 05:51 PM
06megacabman's Avatar
Started running TCW-3 with Stanadyne every other tank.
Old 11-16-2007 | 07:01 PM
coparam4x4's Avatar
On my 2nd gallon of 2stroke...The motor loves it...
Old 11-17-2007 | 10:56 AM
donnee's Avatar
Iv been running Walmart brand 2 stroke as well and it works really well.
Iv also read that on the newer (07 and up), Cummins reccommends no additive be used at all.
Old 11-17-2007 | 12:16 PM
bigwheels94's Avatar
I use Power Service , & Racor Lubri-Bor. Made by Parker Filtration. Only needs 1/2 oz./30 gal.
Old 11-17-2007 | 08:33 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
Question How about this?
I was picking up a can of Sea Foam the other day for my mowers and other yard items and a guy came up and bought three cans ahead of me. We checked out at the same time and both walked out. He took two of the cans and dumped them into his agri bed tank. He said he always runs it in his tractors and his skid steers. Has for years. I swear by it for small engines and this guy likes it for his machinery. It seems to be expensive for every tank use, but what about occasionally? anyone use it in the truck?
Chris
Quick Reply: what additives with the new diesel??
